Re: 1988 Case 7120 - excessive blow by
Posted by pistons on March 08, 2013 at 12:30:14 from (67.52.234.226):
In Reply to: Re: 1988 Case 7120 - excessive blow by posted by pistons on March 08, 2013 at 11:11:26:
edit to my above comment. I should have clarified, broken ring lands, would be referring to the piston having a portion broke off. Where does that broken piece go? Either it gets hammered by a valve and pushed out if small enough, or it stays in there and bounces around. Either way, if a ring land is broken, there is cylinder scoring, which will require a new sleeve, and if the valve hit it, then the valves will need replaced in the head. I can only imagine that maybe there is a cylinder that has significant damage. But does a damaged cylinder affect the rest of the engine? Can a fella count on fixing that cylinder, because the rest of the engine is likely not broken, or otherwise damaged from it?
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
