Re: Stuck engine
Posted by Darinj on March 08, 2013 at 16:32:34 from (66.115.214.57):
In Reply to: Stuck engine posted by Brent Holland on March 08, 2013 at 16:25:59:
Find a piston that has or is about to fire need to have both valves closed. Take a old spark plug knock the center out weld a fitting to it so you can hook up a hyd hose to it use another tractor to put hyd pressure to the cylinder it will come loose done this many times
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
