Looking at a 756
Posted by picassomcp on March 08, 2013 at 16:42:03 from (50.107.38.145):
I am looking for a diesel tractor to replace my 706 gasser. My gasser does all the things I need it to but my gosh the gas it uses. I have tuned this baby up and try to keep my RPMs no higher than needed. I use it strictly to run my 9' haybine and it also runs the round baler. I may be plowing up some ground soon and could only imagine the gas it would burn plowing. I have found a 756 diesel close by that I am considering. I have read reviews from this site and by the sounds of it they are pretty good tractors. Rock solid engine and easy on fuel. This tractor is on a middle mans lot, he bought it on auction so there is really no finding out the history on this tractor. It has 9700 hours on it which is quite high on an original engine. Can't tell if the engines been worked on or not. Its clean as a whistle so likely been pressure washed, cant tell if there is any leaks or not. I can see a bit of antifreeze leaking from the rail just above the exhaust manifold. Looks to be a easy gasket to replace. The oil has been changed recently, can't tell ifs theres any sign of water in it or not. The price is right at $4800 but I just am a bit uncomfortable with all the unknowns here. Theres gotta be a reason that the last person who actually used this tractor sold it? I haven't heard it run yet, but I'm guessing that the engine needs rebuild. Whats a good way to tell if it needs rebuild or not while its on a dealers lot? Any other potential concerns about a tractor like this? I would like to try it out before committing to purchase but this time of year thats pretty tough. Lots of snow and frozen ground here in central MN. Tires are good but not matching. Ugly cab, no glass in it. But the tin work is very straight, needs paint. Seat is tough. All thoughts welcome and appreciated. Thanks
