Re: Winter Storage Hints?
Posted by Tom W. on November 10, 2000 at 18:14:40 from (166.94.57.228):
In Reply to: Winter Storage Hints? posted by Jeff on November 10, 2000 at 17:58:03:
I would store it like an outboard motor. Fill the gas tank up and put stabilizer in the gas. This way you will not get a condensation in the tank. Run the engine for a while to make sure you have the stabilzed gas in the carb. Don't run the carb dry, you invite condinsation if you do. Spray engine fogging oil in the air breather of the carb until you stall the engine. you can get the fogger and stabilizer from a marine dealer. take out the plugs and spray some fogging oil in each cilinder. Turn the engine over with the plugs out and the ignition off a few times. Put the plugs back in and turn the gas off. disconect the battery and store it fully charged. In the spring, all you should have to do is hook the battery up and start her up. The fogging oil will burn off very quickly.
Post A Followup
: Re: Re: Winter Storage Hints?
