Posted by rustcollector on March 08, 2013 at 17:22:29 from (70.195.194.8):
In Reply to: Stuck engine posted by Brent Holland on March 08, 2013 at 16:25:59:
I am leery of using the tractor hydraulics as described below. Before trying to turn the engine, remove the valve cover and the rocker arm assembly so that if a valve is stuck, you don't bend a push rod. Lub the valve stems and tap lightly with a hammer to be sure the valves are not stuck. Once the valves are all seated, use the hydraulic pressure method but with hydraulic oil, ATF or other favorite concoction in the cylinder and compressed air pressure and let it set for a few days under pressure if necessary would be my first attempt. It would help to lub and pressurize each cylinder for a few minutes, then letting the cylinder that is just past TDC sit with air pressure. Hydraulic pressure from another tractor is enough to bend or bust engine components (about 10 times high combustion pressures).
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
