Re: H compression
Posted by Bob R on November 10, 2000 at 18:31:25 from (209.198.80.35):
In Reply to: H compression posted by Marvin on November 10, 2000 at 15:57:30:
try taking compression with a warm engine . I've found a cold engine your readings are all over the map . After you take the reading , add a teaspoon of oil to the plug hole then take another reading . If your compression goes up , you have worn rings .
Post what you find out
A valve job can get spendy quick . They can need new valves and seats .The guides are not expensive .
But you can put 400.00 in the head alone with parts and labor . Rings are about 100.00 bucks
plus a gasket set . I would think your compression would be livable considering the age . Does it burn oil ?
Post A Followup
: Re: Re: H compression
