Posted by mkirsch on March 09, 2013 at 04:33:16 from (67.253.161.186):
In Reply to: Farmall Super M-TA posted by tractorguy2000 on March 08, 2013 at 22:17:01:
Someone has replaced the rear hubs on your Super M-TA with ones off a 400.
The correct hub for a Super M-TA only has 6 large holes, 6 lugs, and a drop center rim. Yours has 8 holes, 8 lugs, and a double-bevel rim. Combined with the A casting code indicates that they belong on a 1955 Farmall 400.
I have never seen hubs with the wheel weights "twisted" like that. Very strange. Are they both like that?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
