Re: Super A 12 volt conversion - Could you check my schematic?
Posted by Janicholson on March 09, 2013 at 05:09:38 from (74.60.94.18):
In Reply to: Super A 12 volt conversion - Could you check my schematic? posted by GRAPE-DRANK on March 08, 2013 at 20:25:21:
I agree: with the diagram except as noted by the Bob and mkirsch. The coil must be a "no ballast resistor required" full 12v design. The 2ga. wire to the starter must go through a switch or relay at the starter.
I put fusable link protection in the charging circuit (either at the alternator, or at the amp meter to battery connection). My reason is that if a diode pack is shorted, or someone jumps it backwards, it fries a 5 dollar fuse link and not the rest of the wiring with possible fire. Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
