H Brake Oil Seal Tool
Posted by FBH44 on March 09, 2013 at 05:16:22 from (64.85.215.91):
After destroying a couple of oil seals trying to tap new ones into place with various dowel rods and steel bars, I found the perfect tool; a white 3x2 PVC DWV [drain/waste/vent] plastic bushing, measures 3 1/2" OD by 2" ID. Fits right around the splined shaft, and holds the seal right up in place as you tap it. Taps it right in. Just FYI, if you"re trying to do this job.
Seal numbers are;
Chicago Rawhide # CR-541901-USA
Case-IH CNH # 76510-C-91
NAPA SKF # 23184.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
