Its so close and I agree with the other gents great advice, but not to be too over picky lol Id prob use 14 or even 12 gauge stranded wire versus 16 (where you show 16) even if the difference is not hardly measureable and in millivolts, juts how Im wired, I a CONSERVATIVE remember who despises voltage drop even where negligible, especially in the ignition (4 amp) circuit.........
Your un ballasted coil may be labeled "12 volts" or "12 volts NOT for use with ballast" or "12 volts no ballast required" etc but NOT one labeled "12 volts for use with or requires ballast!!!!
As far as the overcurrent protection that Jim and others mentioned, Id probably use 15 to 20 amps (depends on wire size used actually) in the ignition/load circuit (placed at ammeter output) and 60 to 80 (depends on alternators output) in the alternators output circuit. I usually use 10 gauge where you show it in the charging circuit although the alternator (depending on its rating) puts out more then 30 amps. Of course, a wires ampacity is much higher in "free air" then when jacketed or enclosed in counduit......
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
