d282 has you on the right track.When you have the small plate off the clutch houseing their is a metal pointer that will point to the timeing marks on the flywheel when you turn it to the right spot which will be 8 degrees before top dead center.Ok on the side of the Roosa pump their is a small rectangal plate with two small screws holding it in place.Turn off fuel under tank take the small plate off and rubber gasket.You will see two scribe marks if you have it on No. 1 cylinder if you see one mark turn flywheel one more turn .Then both marks should line up when you are on 8 degree mark on flywheel.If not you have to rotate the whole pump that bolts to the front timeing cover .Three nuts bolt it to the cover loosen them some and turn whole pump to line up the marks when they line up tighten nuts.Then put everything back together.Then bleed pump if it has air in the sustem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
