That is not an easy question to answer. I've got a model J on my 450, and the model J with the standard spring is supposed to be good for about 110 horsepower. Your 806 came with an Ensign, right? The problem is I don't know if your engine will idle down very well with the Impco model J. My factory Ensign regulator had some kind of idle circuit through the regulator, not just through the throttle body ("carburetor"). But it runs just fine on the Impco, it just won't idle down below about 600 rpm. Any questions give me a call, 318-465-0797. Good luck.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
