Re: Farmall C-263 ignition
Posted by CNKS on March 09, 2013 at 18:21:00 from (216.144.104.128):
In Reply to: Farmall C-263 ignition posted by Elder Al on March 09, 2013 at 14:42:43:
If there is any difference-I don't have the advance specs-the difference is the advance springs and/or the weights, I think only the springs that determine the advance. The rest of the distributer is the same. Same thing with the 4 cylinder engines. The C263 is used in more than one tractor, the advance probably depends on the compression ratio, also if the owner changes pistons with more or less compression in the same tractor.
