Posted by D Slater on March 09, 2013 at 18:39:27 from (184.15.17.95):
In Reply to: Fast hitch 450 posted by 660 guy on March 09, 2013 at 16:59:47:
When the hitch was new and the traction control handle was all the way down it helped on the moving. But they would still have some back and fourth. If you don't need to raise or lower the hitch, putting the lift links in the holes near the lift shaft will help. The holes are on the bracket that bolt to the transmission housing. Or if you weld some things can be done at the bracket under the transmission. One way is to weld up a stop block. Picture of one I did, mounted with 2 bolts. I remove the bolts and steel block if I want to use the traction control. If you never want to use the traction control, you could weld the bracket solid.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
