Re: Disconnect Transmission Countershaft Coupling
Posted by Eastsider on March 09, 2013 at 18:47:07 from (24.225.112.14):
In Reply to: Disconnect Transmission Countershaft Coupling posted by F4RM@11 on March 09, 2013 at 18:36:25:
If you have the belly pump, you need to rotate the pump so the
coupling is vertical on one side, then lower the whole pump to
get it out. That would mean disconnecting the piping etc... At
least that is how you do it on a regular M.
