Re: Disconnect Transmission Countershaft Coupling
Posted by F4RM@11 on March 09, 2013 at 18:53:30 from (50.126.203.237):
In Reply to: Disconnect Transmission Countershaft Coupling posted by F4RM@11 on March 09, 2013 at 18:36:25:
So if the female coupler on the pump is vertical (which it nearly is in the photo), then the pump should drop free of the dog? Plumbing and lever will be removed too of course.
I studied photos of the H before heading up to the farm, but obviously the SM uses a different and shorter dog.
This post was edited by F4RM@11 at 18:55:19 03/09/13.
