Re: Farmall C-263 ignition
Posted by The tractor vet on March 09, 2013 at 20:12:50 from (75.24.0.48):
In Reply to: Farmall C-263 ignition posted by Elder Al on March 09, 2013 at 14:42:43:
You are correct as they are curved for the tractor that they are to be used on . It is not only springs and weights it has to do with the plate . Do not just use some brass stock for this as it will not work . Don't ask how i know . You can get oil lite bronze from Applied Tech Ind. . I am going to try one more time to rebush the dist on our 706 just as soon as it warms up . As i not only have to redo the dis. but also have to put a new oil pump in as the last try failed after about 4hours and seized up and took the end of the oil pump shaft off . sofar i have not found a dist. for a C291 as it is different then a C263 .
