Posted by Tom Fleming on March 10, 2013 at 04:38:14 from (67.20.233.75):
In Reply to: F-20 magnito problem posted by Andrew Psencik on March 09, 2013 at 19:05:26:
in addition to what Old-F20 said, take a look at the grounding tab that he refers to. I have had a couple of F-4 mags that over time that tab did not make good contact with the points. it can be carefully bent a little to make solid contact with the points when completely retarded on the timing. BE CAREFUL! that grounding tab can be broken off if you use too much force. Clean it first. If you still have the problem, inspect the clearance when the timing is fully retarded. If it is not making solid contact, bend it slightly to correct.
This post was edited by Tom Fleming at 08:07:52 03/10/13.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
