Posted by Tom Fleming on March 10, 2013 at 06:10:42 from (67.20.233.75):
In Reply to: F20 running badly posted by Andrew Psencik on March 09, 2013 at 14:47:38:
so, did you lube the valves before you ran it? Personally, if it hasn't run in awhile, I would use Marvel Mystery oil for the first 2-3 lubes of the valves, and I would overdo it a bit. you cannot over lube the valve train, but you do get to a point where you are just wasting oil. However, if the old girl has sat for awhile, like I said, overdo it. You might even want to take the valve cover off and shoot each valve with oil, and turn it over to watch that they are all moving full travel.
You should oil the valves for the first start every day that you run it.
The other suggestions are valid, but before you go down a whole bunch of different paths, make sure the valve train is loose, lubed, and working.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
