I wouldnt try to remove the bolt on the spring because im not sure you will be able to get it back together after its hooked up. You should put the pin in the hole and then hook up the other end into the rock shaft and then adjust the spring so you can get the bolt in. I hope you are hooking up to the backet in the rock shaft and not to the top of the rock shaft because not all the rock shafts have that little bracket on them.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
