Re: Making progress on the old f20 mag but.....
Posted by oldiron29 on March 11, 2013 at 18:21:13 from (74.88.11.200):
In Reply to: Making progress on the old f20 mag but..... posted by Andrew Psencik on March 11, 2013 at 17:58:12:
Andrew, Rice Equipment in PA. would have a new cap. At the back end of the mag under the tin cover there are 2 little screws in a plate with many hole. you unscrew the screws and move the plate to change the timming and put the screws back. Move only one hole than test run it. You should hear the mag snap when piston is at TDC.
If you remove # 1 plug put a screw drive in the plug hole and crank slow as piston comes up.
oldiron29
