Re: Shifting a Farmall Super M into road gear.
Posted by Zachary Hoyt on March 12, 2013 at 18:19:28 from (184.8.254.26):
In Reply to: Shifting a Farmall Super M into road gear. posted by LanceLarrison on March 12, 2013 at 17:26:12:
With my H I would start in 5th on the flat unless I was pulling
something heavy and then would have to start in 4th and shift
up. My experience is that it would shift up a gear easily but
downshifting while in motion was not easy nor worth the damage
it did to the gears. I found it best to shift slowly and feel my way
into 5th to avoid grinding, this was fine unless I was going uphill
and ran out of momentum. With the TA in the 300 when pulling
a load I could start out in 4th high, step on the clutch and shift
to 5th low and then once I got up to speed push the TA to high
and get up to speed easily. If you have a SMTA it should work
the same way if it has a working TA.
Zach
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
