Re: Got the Super A cranked - OIL LEAKING from filter HELP!!
Posted by Janicholson on March 12, 2013 at 19:26:59 from (74.60.94.18):
In Reply to: Re: Got the Super A cranked - OIL LEAKING from filter HELP!! posted by GRAPE-DRANK on March 12, 2013 at 15:15:23:
The fan belt is designed to be much looser than any normal belt. If you put your thumb on the middle of the span between pulleys, and push about as hard as you can with that thumb, it should move a total of about an inch, from the point of contact to the full push. It will feel lose, it is OK. If an inch and a quarter you might tighten it, or might not. If too tight it will burn out bearings in the Water pump. Jim
