Re: cheap oil
Posted by Jim Naden on March 13, 2013 at 01:28:49 from (12.74.50.69):
In Reply to: cheap oil posted by scotc on March 12, 2013 at 22:10:04:
scotc said: (quoted from post at 22:10:04 03/12/13) Yeah guys, this was a new hydraulic pump, filled with new TSC fluid, and the hydraulic pump didn't last a couple hundred hours even. Can't remember who it was or just how long though.
A former neighbor's kid came up and got some hy-tran from us when their (2955 I think) JD needed topped off (15+ years ago). The PTO went out of it a few days later and the dealer blamed it on the hy-tran. Yet our Case dealer here says that hy-guard will not hurt the IH and CIH hydraulics and transmissions.
After our experience with having to drain the backhoe and replace most of the hoses after using Pitt-Penn hydraulic oil, I stick to name brand oils unless I don't need a whole lot, or it will just leak right back out anyhow.,
The water absorbing characteristic of hy-tran can cause the facings in a John Deere perma clutch to separate, eventually. The simple addition of hy-tran would not cause a failure in a matter of days. First, the oil would need to absorb water, even then it would take quite a while to de-bond the clutch facing material.
This post was edited by Jim Naden at 01:48:42 03/13/13 2 times.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
