Re: Farmall 706 Manifold Heat Riser?? The Tractor Vet - Anyone?
Posted by kpowl on March 13, 2013 at 07:02:07 from (170.54.58.4):
In Reply to: Farmall 706 Manifold Heat Riser?? The Tractor Vet - Anyone? posted by kpowl on March 12, 2013 at 03:04:43:
Thank you very much for taking the time to reply. The instruction sheet is great! This is the exact information that I was looking for. Thanks, again
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
