Re: Remote hydraulic valve question for Super A or Super C
Posted by gene bender on March 14, 2013 at 07:38:32 from (67.55.226.151):
In Reply to: Remote hydraulic valve question for Super A or Super C posted by Rtr on March 13, 2013 at 15:41:25:
You dont want to use the original valve assy that was used on the SC with fast hitch it will not work. I worked on one that did that and it was a mess to raise the loader. mJust use the block then get a double valve assy then you can use the loader off one valve and remote off the other or just add another valve in series with the one you are using the loader for. The hy oil needs a path thru both valves then to the rockshaft assy on the tractor. The one i did some work on was a mess to raise the loader by pulling two levers the same time. Owner said he could use it the way it was but in the future mite have mw redo the system so it would work better.
