Re: Stuck oil pump on 140
Posted by gene bender on March 15, 2013 at 03:02:25 from (67.55.226.151):
In Reply to: Stuck oil pump on 140 posted by Pacerman on March 14, 2013 at 20:38:22:
You can resurface the plate without removing the pump its supposed to be flat therefore the clearence will be just fine the gasket is paper thin.
