Re: Farmall engine size
Posted by mkirsch on March 15, 2013 at 05:40:50 from (64.80.110.74):
In Reply to: Farmall engine size posted by Maytag on March 14, 2013 at 14:05:47:
Engine size should be cast into the block near where you found the part number. Should say "C123."
You can't tell if the bottom spring is adjusted right until the engine is running. Make sure you've got the throttle linkage adjusted right, then if the engine is surging you can turn that screw in a little bit at a time until it stops. In your case you can probably turn it out some.
If you turn it in too far I think it affects throttle response. You want it set where the governor snaps the throttle open and doesn't "bounce."
