Re: Stuck oil pump on 140
Posted by Janicholson on March 15, 2013 at 17:46:58 from (74.60.94.18):
In Reply to: Re: Stuck oil pump on 140 posted by Russ from MN on March 15, 2013 at 07:38:11:
The end clearance should be .0005 to .001" To measure it installed the I would put a 3/4" piece of plastigauge between the (flattened) end plate, and the gears. Remove the plate and measure the plastigauge with its wrapper. The gaskets are very thin oiled paper. CaseIH has them. Jim
