Re: slave to your possessions....
Posted by mkirsch on March 18, 2013 at 05:20:49 from (64.80.110.74):
In Reply to: slave to your possessions.... posted by sgtbull on March 17, 2013 at 05:49:41:
You can't possibly be using all that machinery enough that it requires much maintenance, regular oil changes, greasing, etc..
If you're doing it to keep yourself busy, that's one thing, but if it's causing depression the answer is simple: Pace yourself.
The oil was in the ground for millions of years and it didn't "go bad." It's not going to go bad in a tractor that you only run for a few hours a year, if you don't change it but once every 5-10 years. You don't have to change it every 90 days or annually or whatever schedule you're currently on.
If leaving the oil for that long makes you uncomfortable, have it analyzed by a lab. That will tell you there's nothing to worry about.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
