Re: Tires and rims
Posted by old on March 18, 2013 at 08:24:27 from (209.86.226.11):
In Reply to: Tires and rims posted by dhermesc on March 18, 2013 at 05:43:10:
Most 6 hole and 4 hole implement rims are the same. You can take a 6 hole rim off the JD-14T and it will bolt right on the ford tractor with the 6 hole rim BTDT. One thing to tell him to do before pulling it is grease the wheel bearings learn that one the hard way and lost a bearing and tire and rim because of burning up the bearings. Oh and slow speed only as in less then 30mph
