Re: F20 oiling idea
Posted by Old-F20 on March 18, 2013 at 19:42:38 from (71.7.101.5):
In Reply to: F20 oiling idea posted by Andrew PSencik on March 18, 2013 at 18:19:00:
food for thought
when you dump too much oil in the felt trays where does it go??
yup, the valve train is a 'total loss' oiling system. the excess will run down into the pushrod galleys and then it drains out the back of the block out of that little 3/8 NPT elbow. You do this and you will eventually run your bottom end out of oil then you'll be up s*^# creek without a paddle
As Kirk mentioned, the original system is more than adequate. If you want for your own good nights sleep, get a few more pieces of felt and lay in there to hold a little more oil
