Posted by pete 23 on March 19, 2013 at 17:54:36 from (74.47.40.242):
In Reply to: 460 Platform lever?? posted by picassomcp on March 19, 2013 at 17:39:29:
That lever is for the draft control. What it does is adjust the response to changing draft of a hitch mounted implement. In other words, the harder a piece of equipment pulls, the more the hitch will raise up to lessen the load. It was often advertised as traction control as raising an implement put more weight onto the rear wheels. Later years most manufacturers became a lot more honest and just reffered to all that kind of hitch controls as being draft control. Everyone except IH used hydraulics to do the job, IH said, hey, why put an extra load on the engine, asking hydraulics to lift hitch when a heavier load happens, just use the mechanical linkage of the hitch. Well, it didn't work out very well. IH went to hydraulic also. Latest is electric control over hydraulic. OK, so the farther up you pull the lever, the less draft it takes to affect hitch. You can look at the cam mechanism that it is pulling against and see what I mean. Best thing, just put lever down as far as it will go and leave it there. Also, there is a pin underneath, right below the pin on lower end of cyl that needs to come out for draft control to work, and is best left installed for all other operations. Lots of those pins are out and then the hitch can move up independent of the position of the hitch hydraulic cylinder if some thing hooked to hitch applies up ward force.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
