Re: A Industrial
Posted by CNKS on March 19, 2013 at 18:55:17 from (216.144.104.128):
In Reply to: Re: A Industrial posted by clint evans on March 18, 2013 at 18:53:39:
What gene says--you can double check if you can see the engine serial and the chassis serial which is inside the left seat support, if it is still there. If a B the chassis serial prefix is FAB, engine serial is FABM (M for motor may not be there). If an A both prefixes are FAA. As gene said if the engine is original the serials match unless higher than 201000. If the serials have the prefix IAA it is a modified industrial A, which I doubt, seeing the picture.
This post was edited by CNKS at 18:59:02 03/19/13.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
