Re: Need a Wheel for Fast Hitch Plow
Posted by farmallhal on March 21, 2013 at 17:36:49 from (76.0.41.160):
In Reply to: Need a Wheel for Fast Hitch Plow posted by rtr on March 21, 2013 at 14:02:36:
Are these two piece wheels that are bolted together with three bolts then attached to the hubs using a different three bolt pattern? What is the tire size as I have seen both 8" and 9" tires on wheels as I have noted. I have found that the 9" variety is more common then the 8" ones which I finally located for my IH No. 11 hay rake, Hal.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
