Re: Re: Re: How to get a piston un stuck?
Posted by RED PULLER on November 12, 2000 at 14:17:31 from (206.147.21.71):
In Reply to: Re: Re: How to get a piston un stuck? posted by Canadian Cowboy on November 12, 2000 at 09:44:04:
WE HAVE FOUND THAT A MIXTURE OF DIESEL FUEL AND COCA COLA SODA WORK FAIRLY WELL. MIX ABOUT 50/50 AND POUR ON THE PISTON. ALSO IF YOU HAVE ANOTHER TRACTOR YOU CAN USE THE HYDRAULICS AS A PRESS. JUST PUT YOUR HEAD BACK ON AND MAKE AN ADAPTOR INTO THE SPARK PLUG HOLE OFF THE BAD CYLINDER. ONLY IDLE THE TRACTOR SO AS NOT TO BUILD TO MUCH PRESSURE. GOOD LUCK!
Post A Followup
: Re: Re: Re: Re: How to get a piston un stuck?
