Posted by mkirsch on March 22, 2013 at 05:42:11 from (64.80.110.74):
In Reply to: Farmall 826 Hub posted by Tyler Gregorius on March 22, 2013 at 05:16:19:
If the hub isn't broken...
Slip a shim made from roof flashing in between the hub and axle on the keyway side to give the wedges a better bite.
The wedges should be out toward the outside of the hub, not sucked into the middle. We had that problem with the 1066. The wedges would suck right in and the wheels would slide if you touched the brakes on a turn.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
