Re: Farmall 826 Hub
Posted by DeltaRed on March 22, 2013 at 06:40:09 from (71.208.220.227):
In Reply to: Farmall 826 Hub posted by Tyler Gregorius on March 22, 2013 at 05:16:19:
Didn't say if you have 'wedge-lock' or the U clamp wheels...Either way,you have some worn parts.Hopefully it is just the wedges.Try the sheet metal metal method.If that doesnt work,time to replace some parts.You said they were TIGHT and still move...You need to use a 3/4 drive and a 4ft cheater.....If not,the wheel will come loose/move.IH recomended around 400 ft-lbs torque on the wedge... Good luck.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
