Re: SH wont fire
Posted by El Toro on March 22, 2013 at 18:26:56 from (108.3.218.181):
In Reply to: SH wont fire posted by IAtractorKid on March 22, 2013 at 17:15:48:
Hold your hand over the throat of the carburetor while a helper makes an attempt to start the engine. See if there's good suction. If the suction is weak pull the sparkplugs and do a compression check. Write down the readings you get and post them on here. Low suction is an indication of low intake manifold vacuum. You need that manifold vacuum to suck the atomized fuel into the combustion chamber. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
