Re: Wide front from 450 = wide front on a 300?
Posted by mkirsch on March 23, 2013 at 00:27:39 from (64.80.110.74):
In Reply to: Wide front from 450 = wide front on a 300? posted by Joe in CA on March 23, 2013 at 00:23:04:
not without some cobbing...
The frame rail spacing is wider on the 450, so you'd have to cob up an adapter plate or something.
The knees are taller on the 450 front end, so the 300 would run even more uphill than it does now.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
