Re: How to get a piston un stuck?
Posted by Dale13 on November 12, 2000 at 16:28:18 from (208.170.79.4):
In Reply to: How to get a piston un stuck? posted by Canadian Cowboy on November 11, 2000 at 18:34:15:
There are a lot of methods to loosen a stuck piston. A good penetrating oil[everyone has a favorite]such as Croil,Zep or blaster sprayedin and then jacking up one wheel and rocking it back and forth and then letting it sit maybe with a weight hung on one side of the tire. then just keep repeating the process. This method works but takes a lot of patience. If you lack this take a rod with a point,a 4 pound hammer and go under the motor and place the point of the rod against the bottom of the piston and wail on it good a few times.The top of the piston will brake out relieving pressure on the sides and rings,take the pieces out and you can then remove the rod . Of course you will need new parts but this does work every time.If you do work for people who have no patience you find short cuts out of need.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
