Re: Farmall 400 3pt/Drawbar Pics
Posted by CNKS on March 23, 2013 at 09:13:15 from (216.144.104.128):
In Reply to: Farmall 400 3pt/Drawbar Pics posted by IAtractorKid on March 22, 2013 at 19:40:11:
The drawbar is ok, maybe better than original but the original drawbar works with Saginaw, the axle brackets are removed and it bolts to the 3 point. The swinging part is also used. The same Saginaw is used with the H thru 450, can be bolted to the 460 and 560 if no fast hitch. The piece that the upper link is attached to is a modification, for a reason unknown to me.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
