Re: Glow plugs needed
Posted by pete 23 on March 23, 2013 at 18:43:27 from (74.47.40.242):
In Reply to: Glow plugs needed posted by John Athey on March 23, 2013 at 16:22:47:
High voltage burns out glow plugs. When you put a fast charger on a battery the voltage can and does get very high depending on state of charge of battery and rate of charge being pushed into battery. Not unusual to exceed 16 volts. Normal regulated voltage of system will not get high enough to burn them out but it is right on the edge. I know nothing about aftermarket glow plugs as all I ever have used were from IH.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
