probably stuck from condensation, at least the valve guides must be in good shape or the valves would not get stuck. yes when stuck open the pushrod will fall out when engine is turned over.i have been sucessful in using a long screw driver through plug hole to push them back up with lubrication. just keep lubing and tapping on valve lightly and working up and down and it should free up. valve will not visit piston just from being stuck. no need to pull head either unless all else fails. if you get valves free then work it for a bit and check compression then you will know what you have for engine condition.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
