Posted by pete 23 on March 24, 2013 at 12:43:30 from (74.47.40.242):
In Reply to: Farmall M dead short posted by MarkO186 on March 24, 2013 at 07:39:11:
First of all, you have to have continuity between the terminal on starter and ground for starter to operate. If starter does not turn over when hooked to battery while off tractor and you get heavy sparking, it most likely is short circuited. I would remove band, put a piece of insulation like paper under the two hot brush's. If you still have sparks, field circuit is shorted. If no sparks, armature is shorted. Could be through bolt rubbed through insulation, remove one through bolt at a time to check. Often times you can see on a bolt if arcing has occured.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
