Re: SA hyd. not working
Posted by gene bender on March 24, 2013 at 14:16:53 from (67.55.226.151):
In Reply to: SA hyd. not working posted by gregthedc on March 24, 2013 at 14:12:04:
Did you check the hy fluid as the front seal just mite be leaking into the crankcase and you are low on fluid.
