Re: Super M liftall shaft seal
Posted by pete 23 on March 25, 2013 at 10:07:07 from (74.47.40.242):
In Reply to: Re: Super M liftall shaft seal posted by Dave S. on March 25, 2013 at 09:50:57:
I too often hear about putting a rod down fill hole and I do agree that would be a real good trick. The only thing you will get out of doing that is feeling the bottom of the reservoir. What the book actually says, or if it is a misprint, should say is that you put the rod up throuogh the intake of the pump after the pump is removed from the reservoir. I would be darn careful doing that also. Just give it some darn good raps with a brass drift and hammer on the coupler in a counter clockwise direction or hook it to an air wrench with a home made adaptor.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
