I didn't mean the gear needed removed. Just that if the coupling won't come loose from the outside the plate needs removed from the reservoir and then the gear on the coupling shaft can be blocked from turning.
Hole to access gears is the square looking part of the pump housing in picture. Opening is turned down to the bottom of the reservoir and the opening is close to the bottom. Lot more distance up inside to the gears from opening than distance from opening to the bottom of the reservoir housing. Book is wrong if it says block through the fill opening.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
