Re: Red knowledge help C123
Posted by WellWorn on March 25, 2013 at 18:33:27 from (67.246.141.21):
In Reply to: Red knowledge help C123 posted by F-Dean on March 25, 2013 at 16:39:51:
Hi Mike. I am not an expert down to specific serial numbers (and don't have my references currently on hand), but to elaborate slightly, I do know that the SA (and B, BN, or SC) from about '53 and earlier was originally a C113, which was "thermosiphon" only (no water pump). If you had water pump (and an oil dipstick rather than only test cocks on the oil pan), the engine would have been replaced with a newer one.
It is possible to put 3 1/8" sleeves and pistons in the 3" bore C113 to boost the cid to 123, but you wouldn't know if it has already been done unless you pull the head to measure.
If you are doing a restore, or just looking for parts to make it work, an invaluable resource is the TC-39 parts book (available from the YT store here) which gives original and updated part numbers for the SA.
Enjoy your SA - they are amazing little tractors.
Well Worn
