That is not the original engine, it probably came from a 100, 130, or 140, not sure. Those 3 tractors and the Super A1 came with a water pump. On your tractor you do not necessarily need a water pump, you do need a gasket with larger openings for better flow with thermosiphon. What I am not sure of is whether the water passages on your engine are smaller than the ones that are strickly thermosiphon. If that is the case then the head gasket will do you no good and you DO need a water pump. Someone else (Jim Becker?) will have to answer that as I am not sure which tractor your engine came from.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
